Properly model contact between shell and solid
    • dddave
      I am modeling a pressure vessel with shell181 elements. The boss is made of solid186 elements. On the shell elements I generate the target170 elements and on the metallic boss conta174 elements are generated.
      To simplify the model I removed the internal pressure. So there should be no tension inside the structure at all.
    • Rahul Kumbhar
      You should use bonded or MPC contact between shell and solid. The contact elements should be on shell elements while traget elements should be on solid elements.n
