Discovery Import
Discovery Import
property step file
    • Guillaume ANFOSSI
      Is it possible to keep the "ADVANCED_FACE" property present in an initially imported step file when exporting to step again ?
      This information seems to change without even a single modification.
      Thanks
    • Charudatta Bandgar
      Hello GUICAD
      Let me check this with the team, I will get back to you.
      Regards
      Hello GUICAD
      I don't think this is possible. Perhaps you will have to try different export protocols to see which one allows it. That seems like that only probable way to retain the information. This lists all the protocols and their differences.
      Other than this. I am not sure if it can be possible with any other way.
      Regards.
