Discovery Import
Discovery Import
Proxy settings for ANSYS discovery?
    • kouji_murata
      I was advised to connect through a special proxy server in my firm, in order to reach the ANSYS license server.  How do you  assign a specific proxy server in ANSYS Discovery?
    • Naresh Patre
      Hello Kouji If you use a network proxy server to reach the internet, ANSYS discovery products will pick up your system settings. The system settings can be configured as follow: Open the Internet Properties window (the left one) then click on LAN settings to open the right window where the proxy server details can be specified: Please let me know if this helps.
      • tyamaguchi
        Naresh Patre Please tell for Kouji-san what address and port number for proxy setting.
    • kouji_murata
      Hello Naresh Patre
      Well, it looks like my proxy settings are already set, but I still cannot reach the license server.
       I believe my system people have to work together with our local ANSYS support to get the right settings, since I have no permission to alter our proxy settings.
      Is it possible to directly consult ANSYS Japan on this case, or is support for Discovery limited to this forum?
      • tyamaguchi
        Kouji 日本語にて失礼します。
        アドレスにhttps://ansys-fno.flexnetoperations.com/・ポートナンバーを443で試して頂けますでしょうか?
    • kouji_murata
      ご回答ありがとうございます
      https://ansys-fno.flexnetoperations.com:443  を試してみましたが,"Error 403 - forbidden"と出てきます。
      やはりプロキシのポリシーで遮断されているのではないでしょうか?
      • Naresh Patre
        Kouji Are you using latest version of Discovery? It was available on Feb 26 on forum.
      • kouji_murata
        Hello Naresh Patre
        Yes, I downloaded the newest version this Monday.
        Please refer to the new started thread "Does ANSYS license server accept user authenticated proxies?"
        I think ANSYS license server does not support connections from user authenticated proxies.
Viewing 3 reply threads
