January 4, 2023 at 11:28 pm
January 9, 2023 at 12:28 pm
Praneeth
Ansys EmployeeHi Harri,
Please check if the nets are imported as required.
Best regards,
Praneeth. -
January 10, 2023 at 8:32 am
Harri Pankratz
SubscriberHello Praneeth,
thanks for the tip, it looks like the corresponding net (in pictures below: "_VB") is not included and all connected parts are dropped as consequence. I am just wondering why the net is dropped.
The resistor "RLC_D210" is connecting the net "_VB" to the net "_VB_RP" (pictures below):Best regards
Harri -
January 10, 2023 at 2:47 pm
Praneeth
The nets might have been dropped due to the warning that some parts are dropped which you informed in the initial post.
To troubleshoot the issue, please raise a service ticket in the customer portal if you have access as this cannot be done in this forum.
Best regards,
Praneeth. -
January 10, 2023 at 3:52 pm
Harri Pankratz
SubscriberThanks, Praneeth!
Best regards,
Harri
- Maxwell, HFSS or Q3D?
- Error
2588
2080
1315
1106
459
