3D Design
3D Design
Pull question
    • seghier
      Hello
      I used pull in python script to create extrusion, and when heights changed the pull created based on the new height
      For example the solid have a height of 10mm, i want change the height to 15mm but with pull it became 25mm
      I used Rhino and extrude don't work like that, Is there a way to use pull based on the origin plane (0,0,0)
    • seghier
      I used this but any suggestions to make it better are welcome.
      import math
      zvalue = 12
      face_z = GetRootPart().Bodies[1].Faces[4].GetFacePoint(0.5,0.5).Z
      selection = Selection.Create(GetRootPart().Bodies[1].Faces[4])
      if zvalue>0 and math.fabs(zvalue-face_z*1000) != 0:
      anchorPoint = Point.Create(MM(0), MM(0), MM(zvalue))
      upToSelection = Selection.Create(SketchPoint.Create(anchorPoint).CreatedCurves)
      rename= RenameObject.Execute(upToSelection,"center")
      options = ExtrudeFaceOptions result = ExtrudeFaces.UpTo(selection, Direction.DirZ,upToSelection,anchorPoint, options)
      Delete.Execute(Selection.CreateByNames('center'))
    • Keyur Kanade
      I am not script expert. But while pulling make sure that you use same anchor or starting point.
      Regards Keyur
