Ansys Products
Ansys Products
pure neumann problem modeling in ansys
    • vkr535
      Hello Team,
      I was trying to model a 2d heat conduction of a rectangular plate with all edge neumann boundary conditions as given in the example 4.9 in the attached pdf. This problem is ill posed and may be solved using the additional constraint as suggested. I was trying to reproduce this problem in ANSYS and see if i could solve, but i couldn't do it as the solver catches the pivot error. I attached the snapshot of the model, which is a rectangular plate with length, L and width W. The bottom edge is subjected to non-zero flux condition, while all other edges are insulated(zero-flux).
      Approach:
      1. The basic idea was to augment the exiting stiffness matrix with extra dof's and then use the additional constraint. So, firstly I meshed the plate with plane55 elements. Then I tried to increase the dof of the model, by adding the extra nodes at the bottom edge and create the combin14(thermal dof) elements with zero stiffness connecting the domain nodes at the bottom edge to the newly created extra nodes.
      2. I then applied the constraint equation(CE) to the newly created nodes as per the eqn(4.129).
      I end up with the pivot error issue and couldnt make it work. I wrote the APDL input below wherein i tried to use the above approach.
      Could you take a look ino this issue and let me know if its possible to solve this
      APDL input:
      FINI
      /CLEAR,NOSTART
      !/FILNAME,dpl_str
      /CONFIG,NRES,100000
      /PREP7
      scopt,no
      seltol,1e-15
      pi = ACOS(-1.0)
      dx=2e-06
      area=0.1
      MP,KXX,1,1
      length_1=100e-06
      length_2=2*length_1
      HEIGHT_1=100e-06
      HEIGHT_3=HEIGHT_1+100e-06
      !! Modelling
      R,1,area
      ET,1,plane55
      RECTNG,0,length_1,HEIGHT_1,HEIGHT_3
      ! Meshing
      TYPE,1
      MAT,1
      REAL,1
      esiz,dx
      allsel,all,all
      AMESH,all
      nsel,s,loc,y,HEIGHT_1
      nsel,r,loc,x,0,0.5*length_1
      cm,edg1,nodes
      allsel,all,all
      nsel,r,loc,x,0.5*length_1,length_1
      cm,edg3,nodes
      allsel,all,all
      *del,sft
      nsel,s,,,edg1
      nsel,a,,,edg3
      *VGET,sft,NODE, ,NSEL,, , ,2
      allsel,all,all
      *voper,sft,sft,eq,1
      ndmax=ndinqr(0,14)
      node_begin=ndmax+1
      *del,ndx
      *del,ttmp
      *dim,ndx,,ndmax,2
      *dim,ttmp,,ndmax
      *vfill,ttmp,ramp,1,1
      *VMASK,sft
      *VFILL,ndx(1,1),RAMP,node_begin,1
      *VMASK,sft
      *vfun,ndx(1,2),copy,ttmp
      *vmask,sft
      N,ndx(1:ndmax,1),NX(1:ndmax),NY(1:ndmax),NZ(1:ndmax)
      etyp_combn14=etyiqr(0,14)+1
      ET,etyp_combn14,COMBIN14
      keyop,etyp_combn14,2,8
      r,2
      TYPE,etyp_combn14
      real,2
      *VMASK,sft
      EN,ndx(1:ndmax),(1:ndmax),ndx(1:ndmax)
      ce,1,0,ndx(1),temp,1,ndx(2),temp,1,ndx(3),temp,1
      *do,ii,3,48
      ce,high,,ndx(ii+1),temp,1,ndx(ii+2),temp,1,ndx(ii+3),temp,1
      *enddo
      /solu
      nsel,s,,,edg1
      sf,all,hflux,0.2
      allsel,all
      nsel,a,,,edg3
      sf,all,hflux,0.5
      allsle
      solve
      fini
    • Ashish Khemka
      The pivot error indicates that the temperature is exceeding in the body. Can you try specifying the temperature boundary conditions as well?
      Ashish Khemka
    • vkr535
      Hi Ashish,
      Thank you for the feedback.
      There is no dirichlet bc's(temperature) for this problem. The idea was to simulate the pure neumann problem as in that example 4.8 using the additional constraint condition. If there is a dirichlet(temperature), there is no issue with the solvability.
      I was wondering if there is a any issue with modeling using the combin14 at the boundary where i specify non-zero flux and satify the constraint condition.
      Thanks
      Vinod
