purpose of youngs modulus and possion ratio in ansys fluent
    • rohan_btech19
      What is the purpose of Youngs modulus and poison ratio during ansys fluent material defining?
      and secondly ,can I directly evaluate the pressure change due to a change in wall thickness of a solid pipe without performing FSI? (its a non thermal problem and pressure based solver )
      Thanks in advance
      It for the intrinsic FSI function. There's a limited structural code in Fluent.
      If the wall thickness changes without effecting the ID then why would the pressure change?
      • rohan_btech19
         Thanks Rob for your help
        If I assign solid material to its wall thickness without changing ID and then can I evaluate the pressure generated on its wall/will pressure change if wall thickness changes as you mentioned it have intrinsic fsi and limited structural code
      The wall thickness changing will effect the wall stiffness which with intrinsic FSI may then alter the ID. You'd probably need a very high pressure for you to see much change though.
    • rohan_btech19
      thanks for the information
      may I the approximately in what orders the pressure should be high
      It depends on the pipe: a balloon only needs a low pressure to distort, not sure I'd fancy trying to blow up a steel bag!  There's almost certainly a stress/strain/bendy calculation in your course notes or on the Learning section here.
      It's more usual to calculate or specify the pressure you have, do some sums (on paper/spreadsheet) to find out what won't distort and order the next tube thickness up from that.
    • rohan_btech19
      Thanks a lot, Rob,
      It would be a great help if you can provide any material or weblink where I can find mathematical relation between solid domain and liquid domain (or where I can see the code of intrinsic FSI)?
      kind regards
      Here  https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_models_fsi.html
    • rohan_btech19
      Thanks for sharing Rob but unfortunately I am not able to access the link due to some login issue.
      So can you please share a screenshot or share through some other method from where I can access it easily.
      Click on Help in the solver, than paste the link into that browser. The solver includes the cookie/token/biscuit that bypasses the log in.
Viewing 8 reply threads
