February 8, 2023 at 9:02 am
David trop
SubscriberI builed some structure and then I entered
mode.run()mode.mesh()
mode.findmodes()
(mode is the name like mode = lumapi.MODE)
and its not working ' like no calculation of the modes appear
some ideas why such thing can happend?
Tnx
February 9, 2023 at 12:40 am
Guilin Sun
Ansys EmployeePlease try some code in this article:
https://optics.ansys.com/hc/en-us/articles/360041873053-Session-management-Python-APITry one at the time and find which line does not work.
In addition, I personally suggest to use the software built-in Python version so it can work seamlessly.
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Negative Reflection Problem
- Simple Optical simulation
- How to calculate the cross-polarization efficiency and phase in FDTD
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
3720
2566
1771
1236
594
