Python Script to save Total deformation and Stress in a specific location (image
    • pavankonchada123
      When I am trying to record the macro for saving Total Deformation and Stress as images using image to file option, I found that script is same for both cases. But how to differentiate between Deformation and stress for automation
      image_settings = Ansys.Mechanical.Graphics.GraphicsImageExportSettings()
      image_settings.CurrentGraphicsDisplay = False
      image_settings.Resolution = GraphicsResolutionType.NormalResolution
      image_settings.Capture = GraphicsCaptureType.ImageAndLegend
      image_settings.Background = GraphicsBackgroundType.White
      image_settings.FontMagnification = 1
      Graphics.ExportImage(r"""D:\Projects\ES.png""", GraphicsImageExportFormat.PNG, image_settings)
    • pavankonchada123
      I want to run this journal file to extract the images
      result1 = system1.GetContainer(ComponentName="Results")
      result1.Edit(Interactive=False)
      DSscript = open("D:scrt.py", "r")
      DSscriptcommand=DSscript.read()
      DSscript.close()
      result1.SendCommand(Language='Python', Command = DSscriptcommand)
    • pavankonchada123
      I have used as this as scrt.py but images are not coming
      '''NOTE : All workflows will not be recorded, as recording is under development.'''
      solu=Model.Analyses[0].Solution
      Graphics.Camera.FocalPoint = Point([0.000000, 0.050126, 0.000000], 'm')
      Graphics.Camera.ViewVector = Vector3D(0.57735, 0.57735, 0.57735)
      Graphics.Camera.UpVector = Vector3D(0, 1, 0)
      Graphics.Camera.SceneHeight = Quantity(0.126253, 'm')
      Graphics.Camera.SceneWidth = Quantity(0.046775, 'm')
      totdef = solu.AddTotalDeformation()
      totdef.EvaluateAllResults()
      Graphics.ExportImage(r"""D:\Projects\TD.png""", GraphicsImageExportFormat.PNG, image_settings)
      equstress = solu.AddEquivalentStress()
      equstress.EvaluateAllResults()
      #endregion
