Photonics
Photonics
Q analysis script understanding
    • Muhammad Danial Haziq Azizan
      My question is how to plot the graph for resonant (a.u. vs wavelength), not the (a.u. vs frequency). Which part I need to change. Urgent..Tqs
      # Q analysis
      # This script calculates the quality factor from
      # the slope of the decaying envelope.
      # Input properties
      # make plots: make plots of signal, envelope, slope, spectrum
      # 1 for yes, 0 for no
      # number resonances: number of resonances to look for
      # Output properties
      # f0: vector of resonant frequencies
      # Q: vector of Q factors of resonances
      # delta_Q: error in Q factor
      # Tags: resonator high q analysis quality factor
      # Copyright 2012 Lumerical Solutions Inc
      # simplify input variable names by removing spaces
      number_resonances = %number resonances%;
      make_plots = %make plots%;
      min_filter_width = 1; # min width of filter in units of resonance FWHM
      max_filter_width = 6; # min width of filter in units of resonance FWHM
      filter_width_test_points = 20;
      zero_pad = 2^16; # fft zero padding
      # Note fft zero pad should be a power of 2,
      # and larger gives more resolution in the
      #frequency domain.
      for(N=0; (N+1) <= nx*ny*nz; 0) {
      N=N+1;} # up to the sum of # of monitors = (nx*ny*nz)
      # get the monitor data for the first monitor
      t = getdata("t1","t");
      field0_t_Ex = pinch(getdata("t1","Ex"));
      field0_t_Ey = pinch(getdata("t1","Ey"));
      field0_t_Ez = pinch(getdata("t1","Ez"));
      # do fft to frequency domain for all monitors
      w = fftw(t,1,zero_pad);
      field_w = matrix(length(w),6*N);
      for(i=1:N) {
      mname = "t" + num2str(i);
      for(j=1:6) {
      if(almostequal(j,1)) { component = "Ex"; }
      if(almostequal(j,2)) { component = "Ey"; }
      if(almostequal(j,3)) { component = "Ez"; }
      if(almostequal(j,4)) { component = "Hx"; }
      if(almostequal(j,5)) { component = "Hy"; }
      if(almostequal(j,6)) { component = "Hz"; }
      if(j > 3.5) { extra_factor = sqrt(mu0/eps0); }
      else { extra_factor = 1; }
      if(havedata(mname,component)) {
      field_w(1:length(w),6*(i-1)+j) = 2*extra_factor*( (1:length(w)) <= (length(w)/2+0.1)) *
      fft(pinch(getdata(mname,component)),1,zero_pad);
      # find resonant peaks, including all monitors
      f_spectrum = sum(abs(field_w)^2,2);
      p = findpeaks(f_spectrum,number_resonances);
      f0 = w(p)/(2*pi);
      # find quality factors
      # reserve memory for results
      peak_spectra = matrix(length(w),number_resonances);
      peak_filters2 = matrix(length(w),number_resonances);
      # calculate slope of decay using 40-60% of time signal
      tp1 = round(0.4*length(t));
      tp2 = round(0.6*length(t));
      t2 = t(tp1:tp2);
      log_field_all = matrix(tp2-tp1+1,number_resonances);
      Q = matrix(number_resonances);
      delta_Q = matrix(number_resonances)+1e300;
      # loop over each peak
      for(i=1:number_resonances) {
      # find FWHM of peak
      peak_val = f_spectrum(p(i));
      continue_search = 1;
      for(p1=p(i)-1; (p1>1) & continue_search ; 1) {
      if(f_spectrum(p1)<=peak_val/2) {
      continue_search = 0;
      } else {
      p1 = p1-1;
      for(p2=p(i)+1; (p2
      if(f_spectrum(p2)<=peak_val/2) {
      } else {
      p2 = p2+1;
      if(p1 < 1) { p1 = 1; }
      if(p2 > length(w)) { p2 = length(w); }
      FWHM = w(p2)-w(p1);
      for(filter_width=linspace(min_filter_width,max_filter_width,filter_width_test_points)) {
      # calculate the filter for the peak
      peak_filter = exp( -0.5*(w-w(p(i)))^2/(filter_width*FWHM)^2 );
      # inverse fft to get data in time domain
      field2_t = 0;
      for(mcount=1:6*N) {
      field2_t = field2_t + abs(invfft(pinch(field_w,2,mcount)*peak_filter))^2;
      field2_t = field2_t(tp1:tp2);
      log_field = log10(abs(field2_t));
      # calculate slope and Q from the slope of the decay
      # estimate error from the slope
      slope = (log_field(2:length(t2))-log_field(1:length(t2)-1))/
      (t(2:length(t2))-t(1:length(t2)-1));
      slope_mean = sum(slope)/length(slope);
      slope_delta = sqrt( sum((slope-slope_mean)^2)/length(slope) );
      Q_test = -w(p(i))*log10(exp(1))/(slope_mean);
      delta_Q_test = abs(slope_delta/slope_mean*Q_test);
      if(delta_Q_test < delta_Q(i)) {
      Q(i) = Q_test;
      delta_Q(i) = delta_Q_test;
      # collect data for final plot
      peak_spectra(1:length(w),i) = f_spectrum * peak_filter^2;
      peak_filters2(1:length(w),i) = peak_filter^2;
      log_field_all(1:length(t2),i) = log_field;
      # output summary of peak results to script window
      ?"Resonance " + num2str(i) + ":";
      ?" frequency = " + num2str(w(p(i))/(2*pi)*1e-12) + "THz, or "+num2str(2*pi*c/w(p(i))*1e9)+" nm";
      ?" Q = " + num2str(Q(i)) +" +/- " + num2str(delta_Q(i));
      Q_matrix=Q;
      Q = matrixdataset("Q");
      Q.addparameter("lambda",c/f0,"f",f0);
      Q.addattribute("Q",Q_matrix);
      Q.addattribute("dQ",delta_Q);
      spectrum = matrixdataset("spectrum");
      spectrum.addparameter("lambda",c/(w/2/pi),"f",w/2/pi);
      spectrum.addattribute("spectrum",f_spectrum);
      # plot the results
      if (make_plots) {
      # plot signal and envelope for first monitor
      field_t_Ex = invfft(pinch(field_w,2,1));
      field_t_Ex = field_t_Ex(1:length(t));
      field_t_Ey = invfft(pinch(field_w,2,2));
      field_t_Ey = field_t_Ey(1:length(t));
      field_t_Ez = invfft(pinch(field_w,2,3));
      field_t_Ez = field_t_Ez(1:length(t));
      plot(t*1e15,field0_t_Ex,abs(field_t_Ex),field0_t_Ey,abs(field_t_Ey),field0_t_Ez,abs(field_t_Ez),"time (fs)","field envelope");
      legend("field (Ex)","envelope (Ex)","field (Ey)","envelope (Ey)","field (Ez)","envelope (Ez)");
      # plot the slopes of the decaying fields
      plot(t2*1e15,log_field_all,"time (fs)","log10(|field(t)|)","Decay for each resonance");
      # plot spectra
      p1 = find(w,0.8*min(w(p)));
      p2 = find(w,1.2*max(w(p)));
      f = w/(2*pi);
      plot(f(p1:p2)*1e-12,peak_spectra(p1:p2,1:number_resonances)/max(f_spectrum)
      ,"frequency (THz)","Arbitrary units","Spectrum of resonances");
      plot(f(p1:p2)*1e-12,f_spectrum(p1:p2)/max(f_spectrum),peak_filters2(p1:p2,1:number_resonances)
      ,"frequency (THz)","Arbitrary units","Spectrum and filters");
      Then, what means by these codes to plot the resonant? why need to multiply 0.8 and 1.2?
      # plot spectra
      • Devika
        Hello, this is simply to set the axis limit. For eg if you change value from 1.2 to 1.8 the X-axis limit will incease to the right side. This wont affect your result.
        Regards
        Devika
    • Devika
      Hello, Can you share mode details? device under simulation and whee you accure this script?
      Can I know who is an expert in this topic? To find the Q factor with the existence of resonant which means calculate the Q factor based on resonant wavelength divided with FHWM. I really stuck using this software
    • Devika
      Hello Muhammad,
      If you are using an academic license, through this forum you can ask questions and reach out to Ansys. Our support team replies most of the questions.
      You can find equation and more details here. Quality factor calculations for a resonant cavity – Ansys Optics.
      If you are new to using FDTD siftware,
      You can refer this manual to learn more about the software: FDTD product reference manual – Ansys Optics
      I recomend to take free course on FDTD: Ansys Lumerical FDTD – Learning Track | Ansys Courses
      Thanks and reagrds
      Devika
Viewing 4 reply threads
