October 17, 2017 at 9:52 pm
natech
SubscriberI have a Q3D dynamic coupling (equivalent circuit type) in Simplorer representing the circuit board my switching converter components are installed on. The linked Q3D project has a frequency sweep in solution setup "Setup 1" over at the frequencies of interest. Does the dynamic coupling allow for simplorer to use the corresponding frequency most appropriate (for instance, at the given switching frequency or resonant frequency of the circuit)? The Q3D solution option for the Simplorer coupling is only Setup 1: LastAdaptive, so I am unsure if that just means Simplorer will only pick one value of the swept frequency. If not, would using a state-space model more accurately account for the frequency sweep solved for in Q3D?
- Maxwell, HFSS or Q3D?
- Error
2646
2110
1337
1116
461
