Quadrupole magnet coil heat transfer
    • Qbzomatique
      I received a task to do a heat transfer analysis of a quadrupole magnet. It consists a magnet coil with a water flowing inside a circular hollow cooling the magnet. Please find here:
      https://www26.zippyshare.com/v/hPiLv4q3/file.html
      https://www26.zippyshare.com/v/ve3FXThn/file.html
      the catia and .stp file showing the construction. Could you do it or show something similar? I have been watching many videos covering similar topics, but I found it very hard to implement in my case from my perspective. The biggest problem I have is with setting the boundaries, The magnet generates 0,95kW and the water inlet temperature is 298K and the ambient temperature is 293K.
      The problem is that I get all the errors regarding the solver and the divergence, actually I tried to do it in several different ways, but always no success.
      I have also been wondering if this could be done with the steady-state thermal workbench module.
      I would really appreciate any help.
      Thank you.
      Best regards,
      Kuba
Viewing 0 reply threads
