October 14, 2018 at 10:21 am
Elfster85
SubscriberHi,
So I'm trying to mesh my model C02 powered car in Ansys for a CFD simulation but it will only mesh successfully when the quality of the curve is very bad (as seen in the "no mesh error").
When I try to decrease the element size I keep getting an error but the curve is actually of high quality ( as seen in the section plane on "failed mesh").
Would really appreciate it if someone could help
Thank you
//Elvin Tiagi
Mesh settings:
October 15, 2018 at 4:07 am
Keyur Kanade
Ansys EmployeeHi,
As ANSYS employee, I am not allowed to download attachments.
As per the images you have inserted, I can see a cut section of the mesh. But I can not see entire geometry or where mesh is failing.
If you are getting error in meshing, please use right click on the message and use go to problematic geometry. It may give location of problematic geometry. You may want to modify geometry at this location in DM or SpaceClaim. At the same time, you can use virtual topology if required. You can use local edge or face sizing as well.
Keyur
October 15, 2018 at 4:10 am
Keyur Kanade
Ansys EmployeeAlso you may want to look at
https://caeai.com/resources/tips-tricks-hex-brick-meshing-ansys-e-learning
Keyur
October 15, 2018 at 11:49 am
Elfster85
SubscriberHi,
Thanks for taking the time to reply! I've looked at the problematic geometry and it seems to be this:
I actually use Autodesk Fusion 360 for CAD and I import in the .step file into ansys. This is how the geometry looks like (highlighted is the part ansys gives an error for):
Do you think the hex meshing in the video will help me here or is it something else?
Thank you
//Elvin Tiagi
October 15, 2018 at 2:38 pm
Ansys EmployeeHave you split/subtracted the car volume from the outer zone? It's hard to tell from the images. Assuming that's the case is a cm scale mesh fine enough to capture the details of the car?
October 15, 2018 at 4:44 pm
Elfster85
SubscriberYes, I have subtracted the car from the outer zone. I don't really get what you mean by cm scale mesh.
Thank You
//Elvin Tiagi
October 16, 2018 at 5:19 am
Keyur Kanade
Ansys EmployeeHello,
The highlighted face may be the problem. From image it looks like it is a single curved surface. Can you please open geometry in SpaceClaim. Then split this face into more no. of faces, may be 3 or 4 faces. You can use Design -- Split command. Then check the geometry by selecting bodies in tree -- right click -- check geometry.
Following videos may help you.
Keyur
October 16, 2018 at 8:25 am
Ansys EmployeeIf you read through the settings you've used the minimum cell size is 1cm: as I don't know how big your object is I was checking that was suitable. The CO2 powered cars I've seen run off a soda siphon cylinder so are typically 5-10cm long.
October 17, 2018 at 3:18 pm
Elfster85
SubscriberHi,
Its worked now! Thank you so much for helping me!
//Elvin Tiagi
October 19, 2018 at 5:11 am
Keyur Kanade
Ansys EmployeeGlad that it worked out!
Keyur
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
