Preprocessing
Preprocessing
quality of mesh
    • swathi
      The minimum quality of my mesh is about 0.01 but only 0.1% of my elements are with this low quality. About 90% of my elements are having 0.9 orthogonal quality. Is this element quality enough? can I proceed with simulation?
    • Keyur Kanade
      ideally you should have min orthogonal quality more than 0.1.
      practically depending on application, you can use 0.01.
      if this helps you, please mark this post as 'is solution' to help others on forum. .
    • swathi
      Thanks for your response Sir,
      Practically depending application means?
    • Keyur Kanade
      on simple applications where not much of physics involved and you are interested in only average flow conditions.
    • swathi
      My geometry is a wavy cylinder. I am getting good quality when I am reducing element size but then I am not getting the wave properly. I am having a total of 21 lakhs elements in which 0.1% is below 0.01 quality.
    • Keyur Kanade
      what models you are using.
      it is better to improve mesh at least to 0.05 or 0.07.
Viewing 5 reply threads
