March 5, 2021 at 5:10 am
alfredoz
SubscriberHello everyone,
My name is Alfredo and I am modeling a structure that is subjected to a horizontal force and an overload, which I have not been able to represent due to failures with certain types of interactions of the structure.
The model consists of a seismic isolator that has a semi ball joint as a base (with friction), and in its column it has an air capsule which is connected with a cable to the base of a plate that rests on the structure to maintain balance .
if I couldn't explain myself well, an image should be able to help.
March 8, 2021 at 7:28 am1shan
Ansys EmployeenUnder mesh, change the physics preference to explicit and check if that solves the issue.nRegards,nIshan.nViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1283
1096
459
