TAGGED: -LS-DYNA-run-time, apdl, cfd-dem, discrete-phase
November 21, 2023 at 6:33 am
CHan Cheung
SubscriberHello LS-DYNA Community,
I am currently engaged in simulating rock-like materials using the De_Bond feature in LS-DYNA and have encountered a specific challenge that I hope to get guidance on.
In my simulations, the rocks are characterized by planar fractures. These fractures are present in two orientations: depth-wise and longitudinally. Notably, the longitudinal cracks exhibit zero cementation strength. My objective is to accurately replicate the behavior of these fractures. To do this, I intend to assign a zero cementation strength to the particles situated along the longitudinal planar fractures at varying depths, while maintaining normal cementation for the remaining particles.
My queries are as follows:
Does LS-DYNA offer a feature that allows for the importation of planar surfaces? If so, can this feature be used to automatically adjust the bond strength of particles situated along these surfaces?
Is it possible within LS-DYNA to track and quantify specific parameters related to the bond, such as the bond energy and the count of damaged bonds during simulations?
I believe these functionalities would greatly enhance the accuracy of my simulations. Any insights, suggestions, or guidance on how to approach this within LS-DYNA would be greatly appreciated.
Thank you in advance for your assistance.
November 22, 2023 at 4:38 pm
Jim Day
Ansys EmployeePlease elaborate on what feature you're using (keyword(s)) that you're referring to as "De-Bond feature in LS-DYNA". Have you already selected a material model for modeling the rock?
Importation of planar surfaces? No, not that I'm aware of.
- Explicit dynamics ERRORS
- turning simulation
- explicit dynamics
- Monte Carlo Simulation
- Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.”
8782
4658
3151
1678
1464
