January 24, 2018 at 8:20 pm
Waleed Ghayas
SubscriberHello everyone! I am doing a final year project related to simulation of waste heat recovery from exhaust gases using Thermoelectric Generators (TEG). Now, we are facing a couple of problems, as I can't find any clear procedure for the simulation.
Could someone explain how I can use two-way coupling to combine Fluent (that we are using to simulate the heat exchanger) with Thermal Electric System. According to my research, this should be two-way coupling, tough I can't find a method for doing two-way coupling.
Secondly, I have found the method to simulate a Thermal Electric Generator on an area of 3mm by 3mm. How can I simulate a TEG on a larger area?
Thank you for your time -
January 27, 2018 at 3:09 am
SubscriberAre you using the Student license or a full license? The Student license does not include the Two-way Coupling system that is in the full license.
February 1, 2018 at 2:03 pm
Waleed Ghayas
SubscriberFull Licence
February 5, 2018 at 10:42 pm
Raef.Kobeissi
SubscriberHello
Can you please describe your problem a little bit more.
Best Regards -
March 7, 2018 at 7:02 am
Waleed Ghayas
2656
2120
1347
1118
461
