Tagged: fluent, heat-convection, heat-transfer, radiation, thermal-analysis
February 21, 2022 at 3:59 pm
_am55_
SubscriberI am modeling three concentric cylinders where the innermost cylinder is long and the two other cylinders are shorter and of equal length to each other. The innermost cylinder represents a chromed brass pipe, the middle cylinder represents a thin, flexible heating element, and the outermost represents insulation. As the pipe is the longest, it has exposed portions where heat transfer (convection and radiation) will occur. Our measured temperatures through physical models is 60C at the heater and 50C at around halfway down the lower exposed portion of the pipe.
March 4, 2022 at 10:38 pmRK
Ansys EmployeeHello,
Can you please give us more information on the applied boundary conditions and solution methods used? Thanks!
2600
2088
1319
1108
459
