February 3, 2023 at 8:19 pm
longt8
SubscriberHello,
I am using HoneyComb MAT 26. I changed the input curve in LCA, LCB, and LCCdirections and I also change the values in EAUU, EBUU, ECUU. However, the reaction force does not change. I see the input stress-strain curve should be positive for strain to simulation the compression. Would you let me know is there any trick thing I need to take care of?
Thank you!
Best,
Teng
February 7, 2023 at 8:26 pm
Jim Day
Ansys EmployeeYour Channel Partner has contacted Ansys regarding this matter via SR 11296883204. I'm in contact with that Channel Partner now.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5386
3367
2471
1310
1022
