Question: Define pipe288 with keyopt(6)=1 in workbench
    • seki
      Dear all,
      I'm performing a structure simulation in workbench, in which needs to define pipe288 with keyopt(6)=1.
      Would you please tell me where to insert the command as following?
      KEYOPT,1,6,1
      Thank you in advance.
      Seki
    • Erik Kostson
      Hi
      Under the line-body on the geometry tree insert the snippet.
      Should be :
      keyopt,typeids(1),6,1
      All the best
      Erik
    • seki
      Hi Erik
      Thank you for your quick response.
      Insert the following snippet under line-body on geom tree, but does NOT work.
      PipeID=typeid
      KEYOPT, PipeID,6,1
      would you like to tell me get the typeid for the line-body?
      Thanks a lot.
      Best Regards.
      Seki
    • Erik Kostson
      PLease use the snippet I sent that is why I sent it:
      All the best
      Erik
      PS: typeids(1) gets the correct typeid for that element and that linebody
    • seki
      Hi Erik Thank you very much.
      It works well.
      Best regards.
      Seki
    • Erik Kostson
      That is great - all the best
      Erik
Viewing 5 reply threads
