Discovery Import
Discovery Import
Question Discovery Live: Internal Fluid Flow with Thermal Effects example
    • tmullins
      Hi, i am trying to recreate the tutorial with internal fluid flow with thermal effects Discovery Live: Internal Fluid Flow with Thermal Effects . When I try to run it from the supplied download I get different results than the video. If I look at the velocity with a initial flow velocity of 2.5 m/s I get a max velocity of 3.1 m/s  and the cross section looks different. At this stage the video shows 5.2 m/s.  Also when i switch to the temp plot it shows that there is no temp.  Am i doing something wrong with this?   Thanks   Tom
    • Subashni Ravichandran
      Hi  mullins.thomas
      The accuracy of result value in Discovery Live depends on the graphics capacity of your system. So it is expected that the end value is slightly different. You can also increase the fidelity and run the model for better results. Although, if you can share your model we can investigate further and check for any discrepancies.
    • tmullins
      Thanks,
      What about the temp not working.  i have tried my own models as well and it dosen't show the temp.
        mullins.thomas
        Please remember to turn on the 'Volume' and then box select to add the temperature. It is a common mistake to forget turning on volume.
    • tmullins
      What do you mean Turn on the volume?  do you mean add to simulation bodies? or do you mean something else?
        mullins.thomas
        In the structure tree, turn on the flow volume component.
Viewing 3 reply threads
