February 2, 2023 at 2:39 am
mk lone
SubscriberHello, everyone,
I used REFIN264 to stimulate rebars, but I don't understand what it means in the command reference(figure.1).
For example,the following command is
secd,2,50.26,EDGo,1,0.5,1,0.5,1
esel,s,cent,x,24,48,,0
secn, 2!
EREINF
There are two questions
1. Do the command mean the orientation of element REFIN264 is identical to the coordinate system of selected elements?
2. What is the element edge(the element coordinate system?)
Many thanks. -
February 2, 2023 at 10:13 am
Erik Kostson
Ansys EmployeeHi
Normally I use them in WB/Mechanical where they are just modeled as line bodies.
I know from the past that it can be confusing and tricky to do this manually via mapdl snippets.
All the best
Erik
February 2, 2023 at 11:24 am
mk lone
SubscriberThanks for your reply, I will use them in WB😆.
February 2, 2023 at 11:29 am
Erik Kostson
Ansys EmployeeThere are some posts about this:
https://forum.ansys.com/forums/topic/reinforced-concrete-with-shear-reinforcement/
https://forum.ansys.com/forums/topic/reinforcement/
https://forum.ansys.com/forums/topic/modelling-concrete-with-reinforcement-using-new-feature/
All the best
Erik
3311
2469
