May 20, 2022 at 11:15 pm
helen.durand
SubscriberThough the ANSYS mesh generation seems to run well for a particular geometry, we are getting the following warnings:
"Hard points are not supported and might be ignored for 3D pre-inflation."
"The selective body meshing is not being recorded, so the meshing may not be persistent on an update. If you want to record the order of the body meshing, please use the Mesh Worksheet to track the meshing steps. Please see Selective Meshing documentation for more details."
What do these warnings mean and would these be issues that could impact mesh quality? How do you recommend resolving them?
In advance, thank you very much for your support.
Research Group Discovery
May 23, 2022 at 3:23 am
Keyur Kanade
Ansys EmployeeThe first warning is there is some point on the face which is not connected to any edge. This face would be ignored for inflation if you have defined any inflation on this face. You can find these faces using Design Modeler  Tools  Repair
The second warning is about recording. It looks like you meshing body by body. So These steps are not recorded. You can record these steps by using worksheet so that you can regenerate the mesh by doing some changes very easily with the same steps. Please go through help manual for more details
Regards Keyur
3862
2631
1859
1254
600
