March 29, 2022 at 1:45 pm
helen.durand
SubscriberGood morning,
I attempted to submit a journal file to Ansys Fluent using batch script and the following error message is displayed:
/wsu/el7/pre-compiled/ansys/2020r1/v201/fluent/fluent20.1.0/bin/fluent -r20.1.0 3ddp -pinfiniband -tcnf=hosts.3314073 -mpi=intel -path/wsu/el7/pre-compiled/ansys/2020r1/v201/fluent -ssh -cx dad5:34889:44575
/wsu/el7/pre-compiled/ansys/2020r1/v201/fluent/fluent20.1.0/bin/fluent: line 680: [: cnf=hosts.3314073: integer expression expected
/wsu/el7/pre-compiled/ansys/2020r1/v201/fluent/fluent20.1.0/bin/fluent: line 701: [: cnf=hosts.3314073: integer expression expected
Starting /wsu/el7/pre-compiled/ansys/2020r1/v201/fluent/fluent20.1.0/lnamd64/3ddp/fluent.20.1.0 -cx dad5:34889:44575
Could you help us to understand what this error means? Attached is my batch script for reference.
In advance, thank you very much for your support.
March 29, 2022 at 2:31 pmRob
Ansys EmployeeStaff aren't permitted to open attachments, please can you post the script? However, if you're using UDFs have you compiled for that platform, and if you used the built in compiler on Win10, is the cluster also Win10?
April 1, 2022 at 11:28 pmhelen.durand
SubscriberThank you very much, Rob. We were able to figure out the issue.
Thank you Research Group Discovery.
2726
2156
1359
1150
462
