Question on .cdat file.
    • wanfadhli99
      After finishing the simulation for wind turbine, I wanted to play the animation in CFD Post. Unfortunately, there is no cdat file type in my saved file. As far as I know, we need cdat file to play the animation(moving animation showing that thw turbine is rotating).
      .cdat is a lightweight data file that Fluent will save if you tell it to. If you didn't switch that on it won't have saved anything. You can also use the case and data files, but with .cas.h5 read in the flpj file ( https://forum.ansys.com/discussion/comment/114915#Comment_114915 )
