Question on setting constants in user-defined function
    • helen.durand
      We defined constants in a UDF code using #DEFINE before writing the macro DEFINE_EXECUTE_AT_END. However, these constants were changing at every time step even though we did not change them anywhere in the code. Would you know what is happening?
      In advance, thank you very much for your support Kind regards Research Group Discovery
    • Swathi V. V.
      May I know the details of the UDF you are using. It will be helpful if you can attach a screenshot of it.
