Question regarding how to model a quasi static simulation in explicit dynamic ANSYS
    • sharkilspot
      I understand that u can simulate a quasi static test in explicit dynamic by ANSYS.
      If I want to simulate honeycomb core uniaxial compression with quasi static state, what parameter shoud I defined ?
      Should I vary the "CFL time step"? or the "staic damping"?
      From my understanding the goal is to have the low kinetic energy right? what about contact energy? (FYI: I use the honeycomb extension to create the specimen, so it has bond type join that might cause contact energy. . . I think, im very ignorant about where this contact energy came from)
      what about "initial condition"? should I define head (the test machine pressure head) as "velocity" or "displacement"?
      Any reply/guidance/tutorial/link regarding my question is highly anticipated.
      Thank You
    • Missy Ji
      check the knowledge materials here any ANSYS customer portal.
      #2042916
      Model Quasi Static processes using Explicit Dynamics with Velocity Scaling
    • sharkilspot
      Thanks for the reply
      Unfortunately I cant access the link, can you help send the pdf to my email (syahiirk@students.itb.ac.id) instead? Much appreciated.
    • Missy Ji
    • sharkilspot
      Thank you so much for the trouble.
      Your post really help me a LOT.
    • djtan
      Ive been enlightened, nThankssssn
Viewing 5 reply threads
