August 4, 2023 at 8:18 am
Miller Testing
SubscriberHello Admin,
I attempted to create a “rough waveguide” structure for my model and planned to add a sidewall angle to the structure, but I am having trouble adding the sidewall angle. I saw other waveguide structures, such as the “Straight waveguide,” that have a sidewall angle feature but without roughness on their sides.
So, I want to ask if there are any methods or ways that I can add a sidewall angle to the “rough waveguide” and/or add a roughness feature to the “straight waveguide” structure?
(I am currently using version Ansys Lumerical 2020 R2.4. I hope this information is helpful.)
Thank you for your help.
Miller
These are the perspective views of the ‘rough waveguide’ (top image) and the ‘straight waveguide,’ (bottom image) respectively.
August 4, 2023 at 4:27 pm
Devika Padmakumar Nair
Ansys EmployeeHello, I would suggest to update the software to new version.
For side wall angle you can use a polygon Tips for adding sidewall angles to simulation objects – Ansys Optics
On that polygon you can add side wall roughness Tips for adding surface roughness to structures – Ansys Optics.
Thank you
August 4, 2023 at 8:53 pm
Miller Testing
SubscriberHello Devika,
I am considering updating to the latest version of the software and I am wondering if there are any new features or updates that could help me design a sidewall angle for my structure. Is there anything in the latest update that could help me achieve this?
I have received your advice to add a polygon to my structure in order to add sidewall angles, but I am wondering if it is possible to add the sidewall angle directly to the rough waveguide structure. Is this a limitation of the version of Ansys Lumerical that I am using, or is there another reason why I cannot add the sidewall angle directly?
Thank you for your help and I look forward to hearing your reply.
Miller
August 4, 2023 at 9:07 pm
Ansys EmployeeHi Miller,
You can find more information on latest release Release Notes – Ansys Optics
This feature might be of your interest Layer builder – Simulation object – Ansys Optics.
I dont think its possible to add side wall angle to a rough surface.
Regards
Devika
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7780
4508
2973
1449
1322
