July 1, 2022 at 2:14 am
July 18, 2022 at 8:37 am
Navya C
Ansys EmployeeHi @yuan_rsy,
It's because most of the magnets have relative permeability close to 1 like vacuum or air.
But if you are using magnets like ferrite, you can check that option.
Navya
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1793
1236
594
