Questions about the general procedure of FEA
    • helen.durand
      Hello!
      My understanding is the general procedure of FEA works something like this (at least for some types of problems): the equations in FEA are written in terms of the displacements (something like Ku=F, where K is the global stiffness matrix created though summing many local element stiffness matrices, and F is a nodal forces vector), and the displacements are first solved for.  Then the strain matrix (sometimes called the B matrix) is used to calculate strains from the displacement results, and matrix representing the relationship between stress and strain (called the D matrix in the theory reference) is used to calculate the stresses from the strains.
      Does this seem like a correct high-level assessment of the FEA procedure?
      Does the overall procedure change for transient or nonlinear analyses?
      Thank you!
    • Ankush Choudhary
      Hi Helen,
      Your understanding of FEA is correct. In the case of transients, we need to use time discretization techniques like Newmark algorithms. In the case of non-linear systems, we need to use an iterative solver like Newton-Raphson.
      There are plenty of courses available on ANSYS Innovation Space related to these topics. These two courses below will help you understand the transient and non-linear solutions.
      https://courses.ansys.com/index.php/courses/fea-linear-elastodynamics/
      https://courses.ansys.com/index.php/courses/computational-resource-considerations-recommended/
