January 15, 2023 at 12:22 pm
jasonsum25
Subscriberhttps://courses.ansys.com/index.php/courses/partially-premixed-combustion/lessons/problem-specification-lesson-1-9/
- I saw from the above tutorial that Partially Premixed Combustion limits only two inflows in the simulation, it is really the case that it would not work if I have a geometry (combustion chamber) with two burners and two air fans?
(Cap from the tutorial)
2. Also, how to determine the mass fraction values for every reactant in this tab in case diesel is used instead of methane? I do not understand how to come up with the values under "fuel" column.
Sincerely thanks for help and answer!!~
January 16, 2023 at 4:07 pm
Ansys EmployeeI suspect you can have more than two boundaries but maybe only two material inputs? Ie one fuel & one oxidiser. What happens if you try adding more boundaries?
For the mixture, you can alter the materials (species) used.
2656
2120
1347
1118
461
