July 26, 2023 at 9:49 pm
BlueSkySolarRacing
SubscriberHello there!
I had a couple of questions regarding a few features of Speos. One of them being the Virtual 3D photometric lab. When using the 3D irradiance sensor and producing a simulation, the results do not provide the average irradiance from the overall shape. Instead it gives a minimum and maximum value. I was wondering how I can get that average value.
In addition, there are a lot of different ways to obtain a source that simulate the sky. I was wondering which of the ambient sources most accurately simulate the sky. In addition, is there a way to isolate just the sun using any of the ambient sources? Finally, when using ambient sources that request for location and time of day, is there a way to know where the sun is located or the direction of the sun.
Thank you in advance for helping!
July 27, 2023 at 2:03 pm
Thomas Martineau
Ansys EmployeeHello,
- I was wondering how I can get that average value
You can use the measurement feature and create an area projected on the shape you will be able to get the average on this area.
2. which of the ambient sources most accurately simulate the sky
The more complete sources are CIE Standard General Sky and Natural Light
3. is there a way to isolate just the sun using any of the ambient sources
Yes, you can use a "natural light" source and put the "with sky" option to false
4. is there a way to know where the sun is located or the direction of the sun.
The sun position is represented in the 3D view (the yellow circles below)
Best regards
Thomas
August 2, 2023 at 2:40 am
BlueSkySolarRacing
SubscriberAwesome, thank you for answering the question. Just a quick follow up/clarification, I was wondering if the yellow circles indicating the sun position just provides the overall direction with respect to the compass.
Thanks!
August 2, 2023 at 7:41 am
Thomas Martineau
The yellow circle give the direction of the sun, refering to the selected axis (nort and zenith) + selected date, time and location.
- how to export results from SPEOS to Mechanical
- Negative Reflection Problem
- Simple Optical simulation
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Ambient source on Ansys SPEOS
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
- HUD simulation Speos
- How I can get a student version of Ansys Speos Software to learn?
- Ansys SPEOS-Fluorescent Material
7742
4502
2959
1449
1322
