3D Design
3D Design
quick tools for selection and deselection in Ansys Mesh
    • AlexC
      For this type of geometry (see below), if I want to select all the edges in the red box (when I do meshing), is there a quick way to do it?
      I’m asking this because quite often I need to handle much more complicated cases than this. It’s quite annoying to select them one by one and I can easily miss some or pick nearby edges.
      In some software (for example COMSOL), they have  tools called for "select" and "deselect". I can simply move the mouse to draw a box to select or deselect all the edges within that box. It’s very convenient. I wonder if there are similar tools in Ansys Fluent. I didn’t find them.
      Thank you!
      Alex
    • Karthik R
      Administrator
      Please go to the Views Tab. Under the 'Mouse' group, please change the default setting of your left from 'mouse-rotate' to 'mouse-multi-select'. You should then be able to use the left-click to draw the box and select multiple elements in Fluent.
      I hope this is what you are looking for.
      Thank you.
      Karthik
    • Keyur Kanade
      here is box selection option.
      you can also look at
      Keyur
    • AlexC
      Hey Karthik,
      Not sure if we are talking about the same version of Ansys. I didn't find the "mouse" group under View Tab. Below is my screenshot.
    • AlexC
      Hello Keyur,
      This works. Appreciate your help!
      Thank you.
      Alex
    • Karthik R
      Administrator
      My bad - I misunderstood the question. I put too much emphasis on the line " I wonder if there are similar tools in Ansys Fluent" was talking about Ansys Fluent.
      Thanks, Keyur, for identifying and chiming in with the right answer.
      Best,
      Karthik
    • AlexC
      Oh sorry. I did make my question clear. Right I was asking how to do the named selection in meshing actually. Thank you Karthik.
      Best,
      Alex
Viewing 6 reply threads
