December 1, 2022 at 6:57 am
Frederic Wu
SubscriberHello,
The optimization issue is still present like in this post: https://forum.ansys.com/forums/topic/optimization-4/
I would like to check the reasons why R is incorrect in size.
R is the name for my DFT monitor. How can I check if it is incorrect in size? I saw earlier answers but could you elaborate on this more?
If possible, could you check out this file as well?
https://drive.google.com/file/d/1UFfB4jqIQWzXBBt_8HJlAI3pFJ-34rEe/view?usp=sharing
Thanks.
December 9, 2022 at 8:08 pm
Kyle
Ansys EmployeeHello,
Please follow up with this issue on the original topic. In the future, please keep discussion on a single issue in one topic.
- Error on Lumerical device
2524
2066
1279
1096
457
