Ansys Products
Ansys Products
R18.0 ANSYS Student installed on Surface Pro 4. Edit bars moved among each other.
    • Adil
      Hello.  I have installed Ansys Workbench 18.0 student software. This works when you open it, but the edit bars (tool bar, see the Picture) on the left side are moved among each other. In addition, the font size is far too small. I need your support.  How can I fix this? Thank you
      Hallo.  Ich habe ANSYS Workbench 18.0 Student Software installiert. Dies Funktioniert zwar beim Öffnen, aber die Bearbeitungsleisten auf der Linken Seite sind unter einander verschoben. Zudem ist die Schriftgröße viel zu klein. Ich brauche Eure Unterstützung.  Wie kann ich das Beheben? Vielen Dank und schöne Grüße
    • pgl
      Can you please review this thread about display resolutions and settings.
    • pgl
      Did the other thread solve your GUI problem?
    • Adil
      Hello PGL, thanks for the Information. I changed only Resolution 1920 x 1080 it is enough?
      Where can i find Compatibility select "Disable display scaling on high DPI Settings. Thank you.
    • Adil
      Under properties i found only this (see the Picture)
    • pgl
      Don't launch the product, instead go to the ANSYS Workbench shortcut on your desktop (or start menu) and right click to select Properties. Under Compatibility select "Disable display scaling on high DPI settings".
Viewing 5 reply threads
