Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Radial and Tangential Magnetic force on rotor of a PMSM
    • Abdur Rahman
       I am trying to obtain unbalance magnetic force acting on the rotor of a PMSM. Could anybody suggest me how can I obtain radial and tangential force acting on the rotor of a PMSM? Can I get it directly using field calculator, if so, please explain step by step? Also, please explain how can I write the Maxwell stress tensor formula, as shown in the figure, in the field calculator.   Thanks.
      Fx can also be expressed as eqn (4)
    • DELI
      hi, you can use field calculator to create named expression for radial and tangential force.
      Br=ScalarX(ToCylindrical(,offset<0mm, 0mm, 0mm>))
      Bt=ScalarY(ToCylindrical(,offset<0mm, 0mm, 0mm>))
      mu0=1.25664E-06
      Fmst_r= /(-(*(Br, Br), *(Bt, Bt)), *(mu0, 2))
      Fmst_t= /(*(Br, Bt), mu0)
    • GLUO
      Please use the radial flux density to get the radial force.
      For radial flux density in field calculator:
      Input > Quantity > B
      Vector > Scal? > ScalarX
      Input > Function > Scalar > PHI
      Scalar > Trig > Cos
      General > *
      General > Smooth
      Vector > Scal? > ScalarY
      Scalar > Trig > Sin
      General > *
      General > +
      Select Add and set the name of expression as B_radial
    • GLUO
      You can also rightclick the design name to enable harmonic force calculation. The tangential and the radial force will be ready in the report. MST is defined as Fmst_r=(Br^2-Bt^2)/(2*mu0), Fmst_t=Br*Bt/mu0.
      GL
Viewing 3 reply threads
