Discovery Import
Discovery Import
Radiation Calculation Error
    • x.li
      Dear Supporter,
      Recently I run a thermal model with a given input temperature, which is time-dependent from 0 to 1000 Celsius, the heat input include convection and radiation to a surface and then heat loss from the opposite faces.
      If no radiation or fixed temperature (such as 100 Celsius) input is included, the model runs well. However, when the radiation input is set to the changing temperature (using a table), the 'Physics' will show 'Partially Updated'.
      I have attached the 'Transcript' message in the attached txt. Please review the message occurred on Sep 26th.
      Thank you very much.
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Brian Bueno
      XIAO_LI
      Are you able to submit the model?
      • x.li
        Brian Bueno Please find the dropbox link (the file is >50 Mb not permitted to attach).
        https://www.dropbox.com/s/p45q64352ol32i4/Base%20model.wbpz?dl=0
        Note that two inputs are considered, radiation and convection, both are temperature curve by a tabled value.
        Thanks for your help.
      • Brian Bueno
        XIAO_LI
        Dropbox is not permitted by our network security.  Can you upload the file directly to this post?  If not I can provide an alternative method.
      • x.li
        Brian Bueno Hi Brain, I said above the file can not be upload due to size. Can you provide an alternative method?
      • x.li
        XIAO_LI Hi Brian, Can you show me how to transmit the model to you?
      • x.li
        Brian Bueno Hi Brian, Can you show me how to transmit the model to you? Thanks.
