Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Radiation efficiency is greater than 1
    • Hozaifa
      hi there,
      I am simulating dual band antenna with very small ground size (20x13)mm using open region setup, I am exciting lumped port.
      I get little higher antenna radiation efficiency which can rich greater than 1 in the higher band (5.6 GHz), could you please help me to find the reason for such error ..!!!
    • Praneeth
      Have you taken into account of the associated parasitics?
      Also can you increase the ground size and see if this is happening?
      All the very best Praneeth.
    • Hozaifa
      thanks for your feedback, I will try them ..
