radiation in fluent
    • ibtissam
      hello
      can some one , tell to me how can i activate  radiation in my model (Discrete ordinate)
      my geometry consists of two solid layers in contact submetted to radiation. and how can i activate the DO/ enrgy coupling?
      i want know what mean the external radiation temperature (exterioir radiation) and the free stream temperature (convection)
      I chose the first layer as semitransparent, so a direct irradiation and diffut are displayed, why?
      thank you
    • Keyur Kanade
      please go through following videos.
      if that helps you, please mark this post as 'is solution' to help others on forum.
    • DrAmine
      Please mark this thread as solved so that other members might take advantage of it.
    • wns2646
      I watched all three videos. May I know how to apply radiation heater (near infrared radiation heater), not the solar radiation?
      The second video clip seems helpful to my question
      You can set wall temperatures, if you want a radiant component that heats up a zone then you need to add an energy input (wall boundary or volume source) to suit.
Viewing 4 reply threads
