March 10, 2022 at 11:42 pm
Shahzaib
SubscriberHi all,
Actually I have an antenna in HFSS with gain and radiation pattern. I want to include measured SnP file of amplifier with it. what is did is to make a circuit file, export antenna there and attached a port with snp file. but it is not plotting the Radiation pattern.
How can I debug this issue?
Screen Shot is attched.
March 22, 2022 at 11:06 amAnchal Singh
You can go through the course Cosimulation Using Ansys HFSS and Circuit - Lesson 2 - ANSYS Innovation Courses. This may help you to achieve what you want.
Hope this helps.
Regards
Anchal
- Maxwell, HFSS or Q3D?
- Error
2684
2124
1349
1136
461
