Raef turbine tutorial not working
    • desouzadacosta
      Hi All,
      I am trying to reproduce the Raef tutorial about a rotating turbine with rotating inertia.
      Unfortunatelly the turbine is not rotating and I get very strange results after some time-steps (see the picture). I am attaching
      the .cas if someone are willing to give a try.
      Any output of what is wrong is very welcome.
      Alex
    • Keyur Kanade
      As ANSYS employee, we can not download attachments.
      Which tutorial? Is it
      Can you please insert images of your set up and procedure.
      Give as much info as possible.
    • desouzadacosta
      Yes. it is. Hey Raef help us !
    • Keyur Kanade
      As ANSYS employees, we can not download attachments.
      Please insert images with more explanation about what steps you followed, geometry, mesh, set up etc.
    • Raef.Kobeissi
      Where are you, stuck guys?
    • desouzadacosta
       the turbine is not rotating and we get very strange results after some time-steps. We believe we followed exactly the steps of your video.
      Would be great if you can take a look at our .cas file.
      Best,
      Alex
    • Keyur Kanade
      if you can insert images of mesh and set up then i can  comment.
      otherwise will have to wait for Raef to look at your file.
      others on forum can also pitch in.
Viewing 6 reply threads
