July 20, 2020 at 7:23 pm
LukasSvoboda
SubscriberHi to everyone,
I'm working on this railway model.
I do not know what I should use at the ends of the railway. - Yellow face
I read an article that says it should be infinite element - for ANSYS - element Infin 257, but I don´t know how to use it in workbench in transient analysis and I am not sure if it is correct model. I consider to use other boundary, but I don´t know which because model has to have same dynamic behavior as real system. Can somebody help me,please ?
Thank you,
Lukas
- The topic ‘Railway model – boundary’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
