Random element in Ansys
    • mekafime
      Hi
      In my model I  found that there are 2 elements type "Solid 187" I think that default is only SOLID186,
             16       476  SOLID186      0.000   0.000000
             17        88  SOLID187      0.000   0.000000
             18        26  SOLID186      0.000   0.000000
             19        14  SOLID186      0.000   0.000000
             20       418  SOLID186      0.000   0.000000
             21        22  SOLID186      0.000   0.000000
             22       440  SOLID186      0.000   0.000000
             23       454  SOLID186      0.000   0.000000
             24       396  SOLID186      0.000   0.000000
             25       396  SOLID186      0.000   0.000000
             26        24  SOLID186      0.000   0.000000
             27        22  SOLID186      0.000   0.000000
             28        99  SOLID187      0.000   0.000000
             29        26  SOLID186      0.000   0.000000
             30        22  SOLID186      0.000   0.000000
             31       234  CONTA174      0.000   0.000000
             33       234  CONTA174      0.000   0.000000
             35       224  CONTA174      0.000   0.000000
      How can I found this element in my model and change to Solid 186 ?
      Thanks
    • peteroznewman
      The SOLID187 elements are Tetrahedral shapes.  Most of the SOLID186 elements would be Hexahedral shapes.
      If you request a Mesh Quality display, pick any mesh metric and the graph that opens up has a number of bars, segregated by element shape. Click on the bar labeled Tetrahedral and you will see which elements are SOLID187.
      There is a degenerate form of the SOLID186 which is also a Tetrahedral shape. Not sure how you tell them apart.
      You can't change a Tetrahedral element into a Hexahedral element because they are different shapes.
      If you can see a way to divide the volume up into six sided pieces, then you might be able to remove some tetrahedral elements.
      Why do you think it is necessary to get rid of the SOLID187 elements from your mesh?
    • mekafime
      Hi Peter
      I thought that if all the elements are solid186 I could have finer results in my model. Thanks!
