January 7, 2023 at 5:19 pm
TJ Rose
SubscriberI am trying to take the data output from a random vibration analysis run on a simplified global model at a designated point and apply that output to a more refined local structure model. My issue is that I have 1500+ data points and I believe there is a way to import that data to the "refined model" without manually typing them into the "Tabular Data" section of the "PSD G Acceleration" input. I've tried "copy-past" from an excel file, but the table seems to need to have the same number of rows already and you can only add one line at a time (so very tedious).. I see that there is a "Import" option, but I have not used that before and I dont understand how to get that to pull the data set... Is there an easy way to pull this data and input it in my model, or do I have to manually type it out?
January 7, 2023 at 9:22 pm
Ankush Choudhary
SubscriberYes, you can quickly insert your frequency vs acceleration data into the table.
Please follow the below procedure:
Firstly, insert your data into the excel sheet and copy the frequency vs acceleration data as shown below.
The second step is to go inside mechanical and right click on the first cell of the table and then click on paste cell.
This way, you will get all your data in mechanical with a single click, as shown below:
January 7, 2023 at 9:30 pm
Ankush Choudhary
SubscriberIf your load data is in .xml format, the import option will work. The file format used to export PSD load data from Mechanical is.xml.
2120
1349
1130
461
