March 14, 2023 at 10:09 am
Antoine ODOBERT
SubscriberHi, I would like to access and modify the rayfile definition (output flux,...) using python scripting.
Can you please give me informations about the python function/class I need to use, and also the ressouces I can use for ansys spaceclaim pyhton scripting in general ?
Thanks
March 14, 2023 at 9:05 pm
Guilin Sun
Ansys EmployeeThis seems for Zemax. If so, please visit here https://community.zemax.com/
March 15, 2023 at 3:00 pm
Antoine ODOBERT
SubscriberActually it is on Ansys Speos. I'm cuurently searching documentation about functions like 'SpeosSim.SourceRayFile.Find' for instance. I can find those functions using Speos, but I can't find any documentation or script examples.
Thank you
March 15, 2023 at 2:59 pm
Antoine ODOBERT
Thank you
March 17, 2023 at 10:23 am
Maxime Cailler
SubscriberHello, you can find all information about Speos API in this section of our user guide:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/Optis_UG_ASP/Optis/UG_ASP/automation_184569.html
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Negative Reflection Problem
- Simple Optical simulation
- How to calculate the cross-polarization efficiency and phase in FDTD
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
3930
2649
1861
1272
610
