September 7, 2023 at 12:13 pm
September 7, 2023 at 4:28 pm
Etienne Arnal
SubscriberHi @Marian, of course if you increase sensor sampling, there is more pixels in the sensor that integrate rays and obviously you need to propagate more rays. So increasing sampling will increase convergence time.
September 8, 2023 at 8:06 am
Marian Wojtowicz
SubscriberHi, but why does it change my result in such a manner? The three areas above are the same locations inside the glazed cabin with different sensor settings. How are we able to say our resolution is good?
I am normally a structures FEA user, so this is a bit of a new field for me. When I do mesh sensitivity studies in mechanical, my results usually do not change dramatically like this. Eventually, they would settle on a certain value.
- how to export results from SPEOS to Mechanical
- Negative Reflection Problem
- Simple Optical simulation
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Ambient source on Ansys SPEOS
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
- HUD simulation Speos
- How I can get a student version of Ansys Speos Software to learn?
- Ansys SPEOS-Fluorescent Material
7742
4504
2971
1449
1322
