June 20, 2022 at 8:49 pm
fdtdisgreat
SubscriberHi all,
Quick question. Does the mesh we set in an FDTD file affect the results of RCWA (using the rcwa script command)? Asking because I know RCWA is semi-analytical.
Thanks in advance!
June 21, 2022 at 7:06 pm
Guilin Sun
Ansys EmployeeNo, RCWA has its own input parameters. As you can see from the online example it only uses the periods and geometry with material properties. details can be found here https://optics.ansys.com/hc/en-us/articles/4414567929235-rcwa-Script-command
June 21, 2022 at 11:29 pm
Kyle
Ansys EmployeeHello mfoley,
The RCWA solver does use a mesh similar to FDTD, but it doesn't use the mesh actually defined by the FDTD object. It calculates its own mesh based on the properties of the RCWA simualtion itself. The mesh of the FDTD object doesn't affect the RCWA simulation.
- Error on Lumerical device
3812
2605
1849
1244
600
