Photonics
Photonics
RCWA, interfaces
    • Ekaterina Pshenay-Severin
      Hi, could you help me understand how to define interfaces in the RCWA object? I'm simulating a Si grating on a Si substrate with a SiO2 superstrate. I'm using "interference reference positions". Currently, I only need one interface at each point, but the discretization of the index is incorrect. Could you explain how I should define the interfaces in this case?
    • Amrita Pati
      Hi Ekaterina,
      The "interface reference positions" are based on the maximum and minimum of each object in the simulation. This is why you see multiple points at the same location as the maximum of one object is same as the minimum of a different object. You can enable only one of these points (same locations) to be selected as the layer interface in the simulation. For example max(substrate) then min(etch) then max(etch).
      Please let me know if you have any further questions.
      Amrita
      Dear Amrita,
      Thank you a lot for the response. This is what I am doing. But the first slab starts almost at -0.4 µm though the interface point is at -0.5 µm.
      The last interface is at 0.72 µm but in the index plot the last point is at 0.6 µm. Why?
      Ekaterina
    • Amrita Pati
      Hi Ekaterina,
      Thank you for sharing more information. Is the refractive index plot consistent with the geometry you have defined?
      Amrita
      Dear Amrita,
      the refractive index plot is not consistent with the geometry. WG MIN is at 0 µm, and the total WG height (WG MAX = etched MAX) is 220 nm.
      Regards, Ekaterina.
    • Amrita Pati
      Hi Ekaterina,
      Thank you for providing more details. Would you be able to share a screenshot of the code you have used to set up the structure group? The inconsistent index plot might be because of an incorrect setup.
      Amrita
      Hi Amrita,
      here it is
      thank you!
    • Amrita Pati
      Hi Ekaterina,
      I tested your code. In this case, you should include, one interface at 0 microns, second at 0.12 microns and third at 0.22 microns. The substrate and superstrate should not be included as interfaces. But the simulation region should extend into the substrate and the superstrate so that the simulation knows which medium the light is incident from and which medium it is transmitted to. The schematic is shown below:
      That being said, as you said the index results provided by RCWA seem to be inconsistent. The co-ordinates seem to be shifting depending upon the location of the simulation region which is unusual whereas the FDTD index monitor is returning the expected results as shown below. This might be due to a bug. I will investigate it further and get back to you as soon as I can.
      Amrita
    • pbiagio
      I am experiencing the exact same problem, the index monitor embedded in the RCWA software seems to provide inconsistent results... however, the electromagnetic results seem consistent with the nominal thicknesses... can you confirm that we can trust 100% the nominal thicknesses that we input in the layout and that the bug regards only the index output?
Viewing 8 reply threads
