Kampus Merdeka Belajar
Ask questions related to general and focused sessions
Re-Displaying The Simulation Graph,Plot,Mesh,Contour,.etc…
    • Welson Adi Putra Bancin
      I've done the run calculation for this simulation,but by something i had to close the simulation. Should i run the calculation, and running calculation has produced residual plots and other graphs that I need. However, when I opened this file again the entire display was gone.Can I display it again? Or should I do "running simulation again"
    • Raihan Lutfianto
      Hi Welson. In workbench Fluent, there are two modules, the "Setup" module and the "Solution" module. If you had saved your model before closing it, you simply can go to the Solution module. To plot the graph you may check the report definitions and monitors menu on the left hand side.
