TAGGED: cfd-combustion, fluent, radiation, species-transport
June 16, 2023 at 1:28 pm
J.LoongHee
SubscriberHi all,
We are seeking advice choosing an appropriate assumption for refractory wall and water cooled tube wall emissivities in a high temperature furnace.The furnace 0.9 x 0.9 x 3.5m.The furnace walls are made of light density, vacuum formed, alumina fibre. Furnace is natural gas and hydrogen fire, and it is fitted with stainless steel water cooled tubesThe focus of the work is predicting radiative heat transfer to the water cooled tubes. These are positioned 50mm inboard of the side walls. There are 5 tubes along each side wall ~0.6m apart.Refractory wall temperatures are likely to be in the region of 1200-1400degC and water cooled tube surface temperatures ~100degC.
Could you advise me on this please?
Thanks
Jee -
June 20, 2023 at 9:35 am
Swathi V. V.
Ansys EmployeeHi,
I would recommend you to refer to heat transfer text books and journals to get an appropriate value of material properties for the working condition.
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7652
4468
2957
1429
1322
